Hi vMixers,
I'm developing a simple
"Activators" program for the Akai MIDI controller models APC mini and MIDI Mix.
It currently has very simple features, but it's the plan to extend the program soon.
Features in current version: - See list of current bindings
- Delete binding
- Add a binding - Bind a input (vMix input) to a MIDI button on a given controller
- Open preset
- Save preset
- Configure which url to use to connect to the vMix webcontroller
Upcoming featuresFlashing buttons
APC Mini allows blinking/flashing a button, and it's my plan to enable bindings to include a setting to choose whether the button must flash.Mapping of buttonsThe mapping of the buttons is dependent on the MIDI controller model. I've attached images to the ZIP, showing the mapping for APC Mini and MIDI Mix.
How it works:First, make sure that
vMix is running and the webcontroller is
enabled, and the
Akai MIDI controller is connected to your PC.
Run the program.
The list of bindings will then be shown in the main window, and it is possible to add and delete bindings on the go.
Adding a bindingFirst step is to choose which MIDI device you will be using.
Enter the button number and select which input you want to bind to.
The midi button/pitch must be the number wanted corresponding to the button on the sheet of button numbers.Finally click add, and the binding will be added.
Colors lighting upAPC Mini lights green if the input is in program, and yellow if in preview.
MIDI Mix only allows each button to light up one color, and therefore, it will only light up if in program.
DemoA demo will follow soon - stay tuned.
DownloadThe current version is attached to this post.
Simply download and unzip the program. The Midi.dll file stay placed in the same folder as this program.
Changelog0.1.1 (02/09/2016) - Fixed bug on faulty names of available devices
0.1.2 (04/09/2016) - Fixed bug leading the program to crash
0.2.1 (09/10/2016) - Added save/open preset feature + opportunity to change webcontroller url
0.2.2 (09/10/2016) - Fixed bug when loading preset
ContactIf you have any questions, feel free to comment the post or contact me at
jens@stigaard.infoFile Attachment(s):
v0.2.2.zip
(424kb) downloaded 316 time(s).You cannot view/download attachments. Try to login or register.
