allegfede
#1 Posted : Friday, August 26, 2016 12:53:03 PM(UTC)
allegfede
hello everybody.
After got my vmix system running (Standard definition), i'm starting customizing some features.
First of all the Virtual Sets for main broadcaster tv shows.
But ... all those included virtual sets are 16:9 ... how can i set a 4:3 background and have it NOT scaled to 16:9 in the inputs?
any sort of TAG in the XML?
thanks
Federico
Bandit62
#2 Posted : Friday, August 26, 2016 1:47:44 PM(UTC)
Rank: Guest
Groups: Guests
just click on the cog (bottom right hand corner) of the virtual set input, and select 'Position', and zoom until you get what looks good for you, or check to see if you have your display and input setting set for SD(720x480)
