Hardware Compatibility
Decklink duo 2 error.. it's shows that's input error
Hi Sir, I am facing input problem.. I just received decklink duo 2 . And my machine specifications are as follows 1. Amd Fx 6300 processor 2. Gigabyte 970 motherboard 3. 8 GB DDR 3 ram 4. 2 tb toshiba HDD 5. Cooler master 500 watt smps 6. BMD Duo 2 7. 2 GB nvidia 210 graphic card So is that enough . Because my it's my maximum budget . I can't effort more. So whats the problem.Is bmd card is not supporting.... Please help me sir......... Regards , Sagar Chandanshive INDIA Sagarm.chandanshive@gmail.com
Quote:A modern mid range graphics card is recommended for vMix. Your card is as budget as it can be. Supported HardwareA FX6300 is comparable to a i3 4330, so do not expect much. I don't know what resolution and how much camera's you want to run, but to me this seems to be clearly not up to spec.
Does decklink duo 2 work on windows 7 ultimate or else I have to update my os to windows 10
It does work on windows 7, yes.
What is the input problem? What does vmix say in the bottom left about cpu usage and gpu render time?
 1 user thanked Mathijs for this useful post.
Input Hardware not found.. Decklink card not found
Is the Decklink card working with Media Express? Please install driver 10.6.5, as that is the most stable at this moment for use with vMix.
Go to https://www.blackmagicdesign.com/supportChoose "Capture and Playback" Scroll down At "Latest Downloads", scroll down until you see: "Desktop Video 10.6.5" Click the "Windows" button Do not fill out the form, on the bottom just choose "Download Only" Install Desktop Video, It will also install the Decklink drivers. It can be that the firmware on the card needs an update. After installing Desktop Video, you will get a dialog if that is the case. Choose to do this and be patient while this is happening. If something happens during that process, like power failure or being impatient and rebooting the system, there is a big chance the card needs to be sent to BMD to get it fixed. If it is done, the dialog will say windows needs to be rebooted.
