Lennart
#1 Posted : Sunday, August 21, 2016 1:20:42 PM(UTC)
Lennart
Denmark
Was thanked: 17 time(s) in 16 post(s)
As it is now, you have to manually check to see if there's been a new release of the desktop capture software.
What I'm suggesting is that a update check is added to the program so it will let you know if there's a new version available.
This should be possible to disable in settings.
