kane wrote:Why not use the NDI VLC plug-in to convert the incoming signal into NDI format and then have vMix 17 (or any other NDI application) receive the signal? NDI Tools (contains the NDI VLC plug-in): http://pages.newtek.com/...Tools-Pack-Download.htmlKane Peterson NewTek I would like to have some more information about this option. I've downloaded the tool, and started the stream in VLC. In what way should I stream this input again, using the NDI plugin?
kane wrote:Why not use the NDI VLC plug-in to convert the incoming signal into NDI format and then have vMix 17 (or any other NDI application) receive the signal? NDI Tools (contains the NDI VLC plug-in): http://pages.newtek.com/...Tools-Pack-Download.htmlKane Peterson NewTek I can think of two reasons why I'd prefer to not do that: 1 - It requires another computer to gateway the feed from the camera. More stuff to setup. More stuff to go wrong. 2 - A transcode pass is from H264 to NDI is not going to help the image quality from the camera. OK, probably won't hurt it much, but it seems unnecessary. I wonder if there's another way to access the audio stream? The surveillance cameras that I use are from Grandstream. They're a little unusual in that they support SIP connectivity. That makes them a lot like an IP phone or a video conference end-point. Using such cameras you can get the video stream via RTSP as has been described. You can also get the audio stream via a SIP "phone call" that can be added into vMix separately, if required. In truth, you can get V+A via a SIP call, but that would need to be gatewayed into vMix in some fashion, so it's not that useful. I do like that I can "call" one of the cameras from the Polycom phone on my desk, see the stream and hear who is at the gate.
All valid points. Just offering a solution that might get it working.
