Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
Hey guys! We at Njastad Webshop has once again come up with a new product/solution, this time, a vMix Telestrator/Drawingboard! --LINK TO PRODUCT----DEMONSTRATION VIDEO-- (PS, horrible drawing-skills are not included) Post any questions, discussion and/or reviews here! Cheers, Håvard [url=shop.njastad.com]Njastadcom[/url]
How do you draw on this? would you be able to release a demo version that says DEMO on it or something to test first?
Do you mean you draw on either the preview window or program window? I really like the Idea.
Joined: 4/25/2014(UTC) Posts: 41  Location: Norway Thanks: 2 times Was thanked: 18 time(s) in 10 post(s)
Hi! You draw with your cursor on eighter the small input window, or one of the big preview og program windows. There is no demo available at this moment. Sorry
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
Joined: 9/8/2014(UTC) Posts: 244 Location: Southaven MS
Thanks: 12 times Was thanked: 26 time(s) in 21 post(s)
Thremir wrote:Hey guys! We at Njastad Webshop has once again come up with a new product/solution, this time, a vMix Telestrator/Drawingboard! --LINK TO PRODUCT----DEMONSTRATION VIDEO-- (PS, horrible drawing-skills are not included) Post any questions, discussion and/or reviews here! Cheers, Håvard [url=shop.njastad.com]Njastadcom[/url] Håvard, I purchased your Telestrator on your website. And it was very easy to add the file as an SWF input. I am trying to determine the best way to accomplish my goal. I am in a separate area as my commentators. I run a batch of cables from my vMix PC to them. Those cables include the Audio cables for their headsets, the Webcam to capture them as a camera input, an HDMI cable (and monitor) so they can see the same screen I am working with. That way they see what is in Preview and what is live. I have 2 cameras capturing the action. 1 is generally wide (full field) and one is zoomed in closer on the ball carrier or ball action. As soon as a good play is over, I will stop the REC on the Video Delay inputs. I will put the one I want to use in Preview, que it up to the right spot and then move it to live for the replay to play again. To incorporate your Telestrator, it seems a simple solution would be the following. Give my commentators a drawing pad like this one http://amzn.com/B00EN27U9U . This comes standard with a USB connection and it has an optional Wireless module. I would still que up the replay in preview run it back and forth a few times so they can see it, Then que it up, move it to LIVE, WITH your Telestrator as an overlay. At this point they would have the drawing Pad where they could telestrate on the replay, then click play. The Drawing Pad can have keystrokes assigned to the 4 buttons. Can your Telestrator file have a "keystroke shortcut" assigned to the clear button? Please let me know if this work flow will work as I think it will. If so I will order a drawing pad. Thanks, Tim
Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Resurrecting zombie thread to see if anyone else is using this?
Can't figure out how to do this when I need the commentators in sports to be able to do the drawing on the video?
Joined: 8/2/2013(UTC) Posts: 1,095   Location: Fairhope, Alabama USA Thanks: 588 times Was thanked: 202 time(s) in 168 post(s)
