iluppiHD
#1 Posted : Friday, August 5, 2016 3:04:41 AM(UTC)
iluppiHD
I'm trying to separate overlay so it can be seen in stream but not in recording.
I've tried to separate these overlays in outputs options without success.
Any ideas, how? For now I have to use external output to FMLE.
[img]https://postimg.org/image/x2jf0ghef/[/img]
Here's link for picture: TV-channel logo
Br, Ilkka Peltola
Mobilestudiotechnician
iluppiHD attached the following image(s):
iluppiHD
#2 Posted : Friday, August 5, 2016 4:33:17 AM(UTC)
iluppiHD
Thanks for your reply.
I now can do the same thing with adobe FMLE via external 2. I'm hoping to hear solutions how to get it done with just one instance of vmix
BETech wrote:
One solution to consider:
On the same computer, enable 'Show Advanced Settings'and enable ‘multiple instances’ from the Settings-Options menu. Ensure you have sufficient CPU/GPU processing power and memory for the executing two instances of vMix. A super-wide screen display or two displays will assist in seeing both instances of vMix.
vMix Instance 1, assign all your inputs for the production except the titles/graphics for overlays. Send your program output to External. Record the production without the overlays in vMix instance 1.
vMix Instance 2
, add a Camera Input as vMix Video as the source (with vMix Audio), and add additional inputs for your titles/graphics overlays. vMix instance 2 will be your down-stream keyer (DSK) for all four overlay channels. Output your program with the overlays via vMix Video External 2 to FMLE/NDI/SDI.
Hope this helps.
kamal
#3 Posted : Friday, August 5, 2016 11:37:35 AM(UTC)
kamal
Could someone explain why there are 6 overlays in the setting while in actual mix there are only 4 overlays !!
and sorry for interrupting the subject
#4 Posted : Friday, August 5, 2016 11:44:00 AM(UTC)
@ kamal
I believe the 2 additional channels are for "Stingers".
kamal on 8/5/2016(UTC)
kamal
#5 Posted : Friday, August 5, 2016 11:53:31 AM(UTC)
kamal
Thanks, I've got it now
appreciated,
