ClementN
#1 Posted : Monday, September 17, 2012 2:04:39 PM(UTC)
ClementN
Romania
I saw different devices for wireless hdmi using the WHDI standard
http://en.wikipedia.org/...s_Home_Digital_Interface
http://www.dvdo.com/air.aspx
http://www.belkin.com/IW...rocess?Product_Id=552222
What about them used in combination with vMix for live streaming ?
Do you think it is a good idea ?
Thank you,
#2 Posted : Tuesday, September 18, 2012 8:10:14 AM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
You're better off going with a professional solution such as the new Paralinx Arrow:
http://paralinx.net/
Home wireless HDMI solutions tend to have a very short range.
ClementN on 9/18/2012(UTC)
ClementN
#3 Posted : Wednesday, September 26, 2012 11:50:47 AM(UTC)
ClementN
Romania
Thank you very much Martin.
We bought one of this for tests and everything works as expected on tests.
Very good idea!
Best regards,
Clement
ClementN
#4 Posted : Thursday, October 4, 2012 1:18:55 AM(UTC)
ClementN
Romania
Hello Martin,
At the time of the message above, we only tested on a monitor.
When tried to test on vMix the video is not shown in the module.
1080i 50 trough IntensityPro
Same cam, same card, same settings are working with wires but are not working trough Paralinx.
On the other hand, the Paralinx is working with the same cam if it is tested on a monitor.
Any idea what the problem is ? Did you tested them with vMix ?
Thank you,
#5 Posted : Thursday, October 4, 2012 2:47:13 AM(UTC)
Can you try the Media Express program that comes with the Intensity Pro and go through all the input
settings options in that to see if you can see the video?
It's possible it is slightly changing the video format from what is in the camera, though I can't be certain exactly what.
Also make sure the Picture and Sync lights are on the receiver to confirm it is getting a good signal.
ClementN
#6 Posted : Thursday, October 4, 2012 3:16:18 AM(UTC)
ClementN
Romania
The blue lights are all ok both on transmitter and receiver.
I'll make the tests with BlackMagic software as sugested and let you know.
I'll try to find out from the producer if (what) is changed on the signal.
