ne02005
#1 Posted : Tuesday, August 2, 2016 8:49:23 AM(UTC)
ne02005
Hi, I have an Akai apc 40 midi controller.
The controller has 127 positions on the optical encoders BUT when I program a shortcut, only takes "one" value.
The only way I´ve found to make a zoom from "0 to 5" in vmix and "0 to 127" on the controller is
adding 127 midi positions... with little increments to cover the full range!!!
The T-Bar works very well! in "setfader"... Vmix Automatically takes de 0 to 127 digital encoder positions.
But "setZOOM" doesn´t have the same options like "setfader"...
It will be great that works with: Position, crop, colors correction... etc
I think that is a ugly limitation in Vmix.
Last night I typed 128 position for working "one camera" zoom... (3 hours of typing)....
Fabian
jhebbel
#2 Posted : Tuesday, August 2, 2016 9:19:45 AM(UTC)
jhebbel
Can you explain a little more what you are looking for? Are you just looking to change an inputs zoom level? Or are you controlling a camera directly?
