Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
Hi all
Is there a programmer out there, which is familiar with NDI SDK and VB.Net?
I don't know how I have to add the dll's to my project. The SDK examples are only for C# and for that case there are some interop files available. So I need some guidance for VB.Net...
Thanks for your help!
Regards, Patrick
Thanks: 7 times Was thanked: 15 time(s) in 14 post(s)
Better off in c# anyway, not sure if the NDI library is compiled with CLSCompliant.
Some update about NDI SDK and VB.net programming.
After some research and testing, I can say: Yes, it's possible.
A good starting point is the WPF C# example included in SDK.
- You have to translate the C# interop files to VB.net and add these files to your project. There are some online converting services for C# to VB.net translation. - You also have to translate all the includes and NDI specific functions to VB.net. If you want to create a Windows Form application, you need to replace some WPF specific code and add some new .Net namespaces to your project.
It needs some work, but as I said, it is possible.
Regards, Patrick
 1 user thanked pm for this useful post.
