Does the combination of vMix and NDI have any ability to cope with a 4:4:4 stream? More specifically, could the vMix Chroma keyer handle it?
I can envision a camera like the forthcoming sub2r device delivering 4:4:4, which would allow for superior quality green screen compositing.
Michael
Joined: 1/13/2010(UTC) Posts: 5,335  Location: Gold Coast, Australia Was thanked: 4735 time(s) in 1624 post(s)
The specs of the sub2r say 10-bit raw RGB. As this is probably a bayer pattern, this would mean two green pixels for every red and green pixel, which when debayered ends up being close to 4:2:2 anyway.
4:2:2 is used at the highest broadcast levels for chroma key and is also what NDI uses, so I don't think there is need for 4:4:4 at this time.
admin wrote:4:2:2 is used at the highest broadcast levels for chroma key and is also what NDI uses, so I don't think there is need for 4:4:4 at this time.
Coming from the broadcast and post-production space, I've worked in 4:4:4, and even 8:8:8 in the past. As you say, it's not used in broadcast, but it is used in post. I accept that it's likely out of scope for vMix. I've seen a few people who were seeking USB 3 attached 4K cameras so that they could derive 1080p @ 4:4:4. In both cases the people asking me about this were taking the result to XSplit.
Thanks: 7 times Was thanked: 15 time(s) in 14 post(s)
mjgraves wrote:admin wrote:4:2:2 is used at the highest broadcast levels for chroma key and is also what NDI uses, so I don't think there is need for 4:4:4 at this time.
Coming from the broadcast and post-production space, I've worked in 4:4:4, and even 8:8:8 in the past. As you say, it's not used in broadcast, but it is used in post. I accept that it's likely out of scope for vMix. I've seen a few people who were seeking USB 3 attached 4K cameras so that they could derive 1080p @ 4:4:4. In both cases the people asking me about this were taking the result to XSplit. 4:4:4 is used in post alot as raw video archive, but at that point if its in post, NDI isn't really much of a concern anymore. If you want to archive in 4:4:4, I would suggest archiving directly at the camera (if possible).
