BETech
#1 Posted : Tuesday, July 26, 2016 10:59:10 PM(UTC)
BETech
I noticed today on the ‘vMix Fun Show’ many questions and some Posts with regards vMix Replay. Most have been dealt with before, but there is one outstanding shortcut that requires attention. The ability to change or modify an existing IN/OUT point for an event.
ReplayMoveSelectedInPoint & ReplayMoveSelectedOutPoint is so 1980’s, not unlike the old Sony Betacam SP or 1” videotape machines. And manevouring the mouse onto the IN/OUT point, and dragging left/right, requires a degree of concentration, and in not so accurate.
A new shortcut ““ReplayUpdateSelectedInPoint” and ““ReplayUpdateSelectedOutPoint” would be quick and easy to implement and efficient for the Operator/Director. So how would it work? The workflow:
1. Select the Event Clip
2. Jog or Shuttle to locaton timecode required.
3. Press the button “SHIFT IN or SHIFT OUT” (SHIFT IN = ReplayUpdateSelectedInPoint : SHIFT OUT = ReplayUpdateSelectedOutPoint
4. Job done in three steps. Frame accuracy at the push of a button.
In programming speak, modify the time value in the InPoint or OutPoint Cell for the currently selected row of the Grid control. Update record for the currently bound Grid control.
Rinsky
#2 Posted : Wednesday, July 27, 2016 3:03:56 AM(UTC)
Rinsky
+1
BETech
#3 Posted : Thursday, July 28, 2016 12:12:49 AM(UTC)
BETech
Version Update 17.0.0.106 now includes “ReplayUpdateSelectedInPoint” and “ReplayUpdateSelectedOutPoint”. Brilliant.
The process of editing or modifying the IN/OUT Points for clips in the vMix Replay event list just became easy as.
With thanks to Martin and his team.
thanks 1 user thanked BETech for this useful post.
Stavlin on 7/28/2016(UTC)
Rinsky
#4 Posted : Thursday, July 28, 2016 12:38:40 PM(UTC)
Rinsky
Hey BETech, what controller do you use for Instant Replay and how are your buttons mapped?
Rinsky
#5 Posted : Friday, July 29, 2016 3:09:23 PM(UTC)
Rinsky
Wow, very complex. Seems like you put a lot of work in it. Thank you!
Guest (6)
