3rd Party Software and Development
Problem with "vMixController" - Status is always Offline
Hi Mac, Hi guys, I would like to know why vMix Controller don't connect with the vMix in my Trial version. I have Windows 8 Enterprise. I have configured all with 8088 port and enabled it. I have put the folder of vMix Controller into di C:\Users\All Users\ But don't work. Please Mac, help me. I need of this scheduler wonderful. If I click on Connect to vMix the status is always Offline.
Thanks, R.
Joined: 10/23/2015(UTC) Posts: 458   Thanks: 20 times Was thanked: 231 time(s) in 130 post(s)
Hey. Please, write about problems with UTC in corresponding thread. This forum not about UTC). I'll answer you in this thread.
Hi elfgard, Thank you for you reply. I have downloaded vMixScheduler of MacJ. but don't work on my pc with Windows 8. The vMixControler have a problem when i click "Connect to vMix" button: the status is always offline. There isn't a message of error. Only the status is always offline. So, I have clicked on "Settings" in vMixController and write 8088 as port (test is OK). In vMix 17.0.0.103 x64 I have cheked the checkbox on enabled in settings, web etc. But don't work. The status is always offline. Please help me. R.
elgarf wrote:Hey. Please, write about problems with UTC in corresponding thread. This forum not about UTC). I'll answer you in this thread. Hi elgarf, Roberto is referring to the controller for vMIx Scheduler, not your tool UTC. Roberto, the vMix Scheduler and is component parts are a non supported product. The code has been made available as open-source but there is no one activley updating or supporting it. It was developed for an older version of vMix so may not work with vMix 16 and 17
@ roberto2101
It (alpha 0.7.14.102) appears to be working fine for me in vMix 17.0.0.105. What version of the vMix Scheduler did you download? Also, did you read through the entire thread? If I remember correctly, there were similar issues for some in W7 or W8, but I cant remember the fix...
