daysonfeliz
#1 Posted : Saturday, July 23, 2016 7:40:20 PM(UTC)
daysonfeliz
Hey Vmixers! I LOVE THIS PROGRAM!
Our church is about to start livestreaming and I had a question in regards to vmix.
We will be streaming the entire 2 hour service on our website, but we would like to stream just half ( the message portion) on Facebook Live. Is this possible in Vmix? I see that we can stream to 3 sources but I believe its simultaneously? If not through Vmix, how would I be able to accomplish this?
Thank you!
sinc747
#2 Posted : Saturday, July 23, 2016 9:48:30 PM(UTC)
sinc747
Was thanked: 207 time(s) in 173 post(s)
Not an elegant solution but you can use FMLE run as a separate program to be your second stream. You would start the vMix External Output which would provide FMLE with a video feed called vMix Video. Also in FMLE you would select an audio source. Set FMLE with stream settings for your 2nd stream CDN. Then start and stop FMLE at will.
This will get you by for the short term.
- Tom
