Set an image for title through scripting
Thanks: 1 times Was thanked: 5 time(s) in 1 post(s)
Hi all ,
I think my request is pretty simple .. i'm just a newbie :)
i know how to change text for titles through scripting (vb.net) here is an example :
dim i = Input.Find("SOCORE.xaml") if i.Text("SCORE_1_A") = "2" Then i.Text("SCORE_1_A") = "3"
But my question is how to change the image for a title through scripting ?? i tried something like this but it's not working :
dim i = Input.Find("SOCORE.xaml") if i.Text("SCORE_1_A") = "2" Then i.Image("SELECT_TEAM_B") = "C:\*********\SELECT TEAM WHITE.png"
Any advises ..
Thanks in advance .
Okay , after deep search , i found a solution for that as following (for anyone who may need it) :
dim i = Input.Find("SOCORE.xaml") if i.Text("SCORE_1_A") = "2" Then API.Function("SetImage", "SOCORE.xaml", "C:\*****\SELECT TEAM WHITE.png", 100, "SELCET_TEAM_B")
New problem arises now , how to get the name of the image assigned to that title (to do if clause on it) ???
Any advise would be highly appreciated .
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
The following example should work: Code:dim xml = API.XML()
x.loadxml(xml)
dim n = x.SelectSingleNode("//input[@title = ""SocialTitle1.xaml""]/image[@name = ""Photo""]")
dim i = Input.Find("SocialTitle1.xaml")
i.Text("Title") = n.InnerText
Hi Martin ,
Many thanks for your help .
One question regarding the following code :
What shall I replace here with my title details ?
Thanks in advance .
@admin
