JimJacobs
#1 Posted : Saturday, July 16, 2016 9:38:47 PM(UTC)
JimJacobs
First is anybody familiar with the BROADCAST ME app? It streams out the IPad camera via RTSP, but I can't get vMix to see it as an input.
Also has anybody come up with a way to get an iPad screen into vMix as an input, so you can use some of the iPad sports apps in video productions.
kane
#2 Posted : Saturday, July 16, 2016 10:12:55 PM(UTC)
kane
NewTek Connect Pro supports AirPlay Mirroring which will allow you to get your iPad screen converted into NDI which vMix 17 would be able to receive.
AlanZ
#3 Posted : Sunday, July 17, 2016 6:03:56 AM(UTC)
AlanZ
Similarly, you could try using AirServer or Reflector to stream the iOS content to your computer via AirPlay, and then use VMix to input the AirServer or Reflector desktop window as an input.
AElli
#4 Posted : Sunday, July 17, 2016 7:09:58 AM(UTC)
AElli
Before 17 and NDI release, we used airsender server ( as said above) running under windows, worked out great for grabbing Mac, win/ android/ iOS devices. But as Kane says above, we now run NDI connect/ Vmix NDI desktop capture.
A.
