zenon
#1 Posted : Saturday, July 16, 2016 6:10:47 PM(UTC)
zenon
I have tried to use the Addinput API function to add RTSP Stream , API send an answer OK back but nothing happend.
I didn't found on help16 or help17 the way to AddInput streams. Do I something wrong or is it not possible ?
What I tried to use is:
http://localhost:8088/api/?Function=AddInput&Value=Stream|RTSPTCP%20rtsp://url:port/vod/filename.mp4
If I add it manually it works well, but I need to add it dynamically over the API.
Is there a way to do this ?
I have actually over 10 customers using VMIX HD and 4 K where I need this function so a tip how to reach it would be very nice !
Thx
Dominique
