Joined: 10/23/2015(UTC) Posts: 458   Thanks: 20 times Was thanked: 231 time(s) in 130 post(s)
That's minimum example of image binding. As I told, I thought about image widget, but SetImage function doesn't accept url's. File Attachment(s):  MinimumImageSourceBinding.xaml (1kb) downloaded 187 time(s).You cannot view/download attachments. Try to login or register.
 1 user thanked elgarf for this useful post.
Groups:: Registered
Thanks: 13 times Was thanked: 3 time(s) in 3 post(s)
elgarf wrote:@Jedda, you can start both timers without noticeable delay.
Button script can contain a lot of functions, which are executed sequentially. So you can start as many timers as you want almost in one time.
With new "link" ability you can also start timers, provided by controller.
Better solution is to try :) Sounds good that it's doable, but I'm a bit unsure as to how to do it. This is what it looks like right now, but how do I make a button that can start/pause all these 4 clocks at the same time? Of course I'm aware that I'll most likely have to adjust all the times manually if I for example pause too late and need to adjust the game clock. But that's perfectly fine, as long as I can start and stop all clocks with one click. Jedda attached the following image(s):  time.jpg (110kb) downloaded 112 time(s).You cannot view/download attachments. Try to login or register.
elgarf wrote:That's minimum example of image binding. As I told, I thought about image widget, but SetImage function doesn't accept url's. Can confirm this method works :) Updating XAMl now for further testing. I have tried on my Team Roster title and its working from HomeBG. Going to update all the Player Profile images and test Starting5. Happy Days.
Starting 5 working from CMS Database XML feed to load player images.
@elgarf Are you able to add disable widget function? So we can turn off the ExternalData widgets when not needed one by one? Eg While I'm testing so I don't change a widget I have already setup I make a copy of it and make changes or add functions but the other one is still active at the same time so I temporarily change the xml url so it return no rows. Be great if can turn off a widget so it doesn't read the xml file or send data back to vmix. Not sure if easy to add but would be handy.
Also Application link when on another pc seems to be brock with 17.0.0.100 was working with earlier versions. Only just notice today when I copied latest template and vmicUTC to my laptop. It looks like its not pulling the inputs from the external IP. If I open the local Vmix its pulls the inputs from local even though the IP is a network IP and says connected. Update state doesn't resolve the issue. Status just reads Update State (Yellow).
Maybe I broke loading state from external ip with latest update. I'll look at this. Disabling widgets is ok, I'll think on this.
elgarf wrote:Maybe I broke loading state from external ip with latest update. I'll look at this. Disabling widgets is ok, I'll think on this. No worries. Yeah not sure why it stopped working.
elgarf wrote:Maybe I broke loading state from external ip with latest update. I'll look at this. Disabling widgets is ok, I'll think on this. Any luck at having a look into the external issue? No worries if busy.
Sometime later, @corporatejames.
Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
THIS IS AMAZING. THANKS A LOT!!!!!!
@corporatejames, I've fixed bug with external PC. Disabling widgets will be later. @Jedda, 1) go to the properties window of timer 2) check "Start" checkbox in the hotkeys section 3) input some text into "Link" textfield - this will be name of event 4) repeat with other timers 5) create button widget 6) add command into script section of button widget properties 7) select ExecLink command into commands list 8) write text, which you have writed in 3rd event of this instruction into "String" field 9) now, when you push button, all timers will start 10) repeat same events for stop button @RC_31, thanks! Updated first post
Groups:: Registered
Big thanks for that guide elgarf, will for sure have a look at this when I get some time. Either way, this is already an awesome tool. It has already helped out a bunch, especially after there has started to be a few minor issues with Raynignons football tool with some vMix updates.
Groups:: Registered
elgarf wrote:@corporatejames, I've fixed bug with external PC. Disabling widgets will be later. @Jedda, 1) go to the properties window of timer 2) check "Start" checkbox in the hotkeys section 3) input some text into "Link" textfield - this will be name of event 4) repeat with other timers 5) create button widget 6) add command into script section of button widget properties 7) select ExecLink command into commands list 8) write text, which you have writed in 3rd event of this instruction into "String" field 9) now, when you push button, all timers will start 10) repeat same events for stop button @RC_31, thanks! Updated first post Got around to try this now, but when I click the start/pause/stop buttons that I've created, nothing happens. Any idea what I'm doing wrong? Attached a screenshot of how the all the time properties look and the button properties. None of the timers start when pressing the start button. Jedda attached the following image(s):  utc.jpg (292kb) downloaded 144 time(s).You cannot view/download attachments. Try to login or register.
Jedda wrote:elgarf wrote:@corporatejames, I've fixed bug with external PC. Disabling widgets will be later. @Jedda, 1) go to the properties window of timer 2) check "Start" checkbox in the hotkeys section 3) input some text into "Link" textfield - this will be name of event 4) repeat with other timers 5) create button widget 6) add command into script section of button widget properties 7) select ExecLink command into commands list 8) write text, which you have writed in 3rd event of this instruction into "String" field 9) now, when you push button, all timers will start 10) repeat same events for stop button @RC_31, thanks! Updated first post Got around to try this now, but when I click the start/pause/stop buttons that I've created, nothing happens. Any idea what I'm doing wrong? Attached a screenshot of how the all the time properties look and the button properties. None of the timers start when pressing the start button. Have you downloaded the latest version from the start of this forum? I had that fault when I first asked for feature and @elgarf fixed it in the next update that the ExecLink worked correctly.
 1 user thanked corporatejames for this useful post.
@Jedda, if you use the last version, please, share .vmc file?
@elgarf confirmed external IP working again. Thanks
@corporatejames, as I understood, you need only disable external data widgets?
elgarf wrote:@corporatejames, as I understood, you need only disable external data widgets? Yeah I think so at this time. Always thinking of great ways you can use it. Just a handy feature. Ideally would be to have that feature I mention before of SetText and SetImage tickbox on the ExternalData widget title mappings. So basically if you tick the box to enable setimage the data value for that title mapping would be a path to image eg C:\images\image.png etc otherwise the field is the normal setText which you have now. Your binding xaml hack is working (thanks) but just much easier to bind within the Widget so don't need a lot of extra titles just to store the image paths.
Groups:: Registered
corporatejames wrote:Jedda wrote:elgarf wrote:@corporatejames, I've fixed bug with external PC. Disabling widgets will be later. @Jedda, 1) go to the properties window of timer 2) check "Start" checkbox in the hotkeys section 3) input some text into "Link" textfield - this will be name of event 4) repeat with other timers 5) create button widget 6) add command into script section of button widget properties 7) select ExecLink command into commands list 8) write text, which you have writed in 3rd event of this instruction into "String" field 9) now, when you push button, all timers will start 10) repeat same events for stop button @RC_31, thanks! Updated first post Got around to try this now, but when I click the start/pause/stop buttons that I've created, nothing happens. Any idea what I'm doing wrong? Attached a screenshot of how the all the time properties look and the button properties. None of the timers start when pressing the start button. Have you downloaded the latest version from the start of this forum? I had that fault when I first asked for feature and @elgarf fixed it in the next update that the ExecLink worked correctly. That was it, now it works just like I want it to :) Thanks guys!
 1 user thanked Jedda for this useful post.
Updated with ability of disabling External Widget and new "Multi State" widget, which translates commands from master vMix system to slave vMix system (so, you can control two or more vMix systems with same configuration through one controller). First post
