Feature Requests
Advertising Play/Scheduler
Joined: 10/27/2015(UTC) Posts: 5 Location: Los Angeles
I would like to suggest an ad scheduler and play list.
We run multiple venues and different advertiser/sponsor commercials and would like to see something in vmix that would support the following
-Schedule Generation (Ordered List) -Play Controls (single list with hotkeys we can indicate run 1 or run 2 and then stop or switch back to preview) --Play List would play next video in list when switching into output -Tracking when video was played along with recorded videos time marker
Regards
Joined: 3/8/2016(UTC) Posts: 123 Location: Anniston, Alabama
You can accomplish most of this through the LIST feature in vMix. You can select your commercials you want to run, then order them within the list as you need to play them out. This can be done within in your production with the LIST as an input. It remembers where it plays from, so when you switch between the list and whatever is in PREVIEW, the next time you run LIST, it resumes from the last event played. Martin is working on improvements to the LIST functionality for vMix 18, and I believe it will eventuality fulfill all the requests you listed. We use it now to play out commercials for sporting events.
Feature Requests
