Increment Number in Recordings/Snapshots vs using Time?
Thanks: 18 times Was thanked: 2 time(s) in 2 post(s)
Is there a way to increment a number for each additional recording (video) and for us specifically for snapshots? eg. 1, next 2 etc. Right now I have a value for a shortcut / snapshots: Code:Snap_{0:yyyyMMMdd_hh-mm-sstt}.jpg
Instead of the time, I'd rather increment a number each time. With time, only 1 snapshot per second is allowed. For Month, I'd rather have the number of the month (06 for June) vs Jun for the example above, is that possible? I tried mm and gave 38 for June.
I got the month in numeric format, thought I had tried MM, perhaps mm was what I tried (that gave an incorrect result). I also changed time to 24 Hour format. EDIT: of course it would, mm for time/minutes. Code:Snap_{0:yyyyMMdd_HH-mm-ss}.jpg
This still only allows one snapshot per second. Perhaps I can add sub-seconds or if there is an option to increment a number I'd go that route and not even use time. For recordings, I use the following for Filename Format: Code:{0}_{1:yyyyMMdd_HH-mm-ss}
Just curious if there is an option to increment a number and/or use sub-seconds (nn or 3N)? We do have the desire to take more than one snap per second, more like 3-5.
