Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
17.0.0.77
* vMix will now detect Windows 10 systems with Optimus (Nvidia laptop graphics) and make required settings changes automatically. Previously a memory error or blue screens would appear in vMix due to a bug in Optimus
* Updated desktop capture to 17.0.0.62 with setting to disable GPU acceleration as it may cause problems on some older systems
* Fixed 60p bug with Blackmagic cards
* Updated NDI libraries to the latest version
 6 users thanked admin for this useful post.
17.0.0.80
* NEW Shortcuts can now have "Hover" selected as the input. This means whenever the mouse is hovering over the video preview of an input the shortcut will apply to that input.
This is great for single shortcuts for things like Audio Mute or Overlays 1-4 that can now apply to any input depending on where the mouse is.
* NEW Low Bandwidth Mode option now available for NDI inputs. This receives a lower quality version of any NDI source that is optimised for low bandwidth. Useful for things like WiFi connections. Note that HD sources are effectively SD (640x360) in this mode.
* NEW Audio Enable checkbox when adding Camera sources such as from AJA or Blackmagic cards where you want to completely disable bringing in embedded audio from a camera.
* Further improvements to Optimus Compatibility Mode * Fixed bug with MultiView output reverting back to the old format after a few hours * Fixed bug with RGB sliders not resetting for presets 1 and 2 in Chroma Key settings * Fixed bug with MP4 Hardware Encoding on Windows 7 systems
* Latest vMix Desktop Capture included
* Also updated vMix Desktop Capture and vMix Desktop Capture Mac to latest versions on download page.
 7 users thanked admin for this useful post.
17.0.0.81
* Fixed high render times in Windows 7 since .77 * Updates now possible from vMix Update for version 17. (16 users will still need to upgrade to 17 manually for the time being)
17.0.0.83
* Fixed bug where setting NDI as an audio output in Settings -> Audio Outputs did not activate that output in the mixer. * Fixed bug that if an error occurred with one MultiCorder, the others may fail to stop.
17.0.0.85
* Added support for X-keys XKE-124 T-Bar * Added support for additional X-keys PID "modes" * Updated NDI to latest version * Updated vMix Desktop Capture to latest NDI version. The latest desktop capture version is now 17.0.0.66
 5 users thanked admin for this useful post.
17.0.0.88 * New direct support for Facebook Live!
* Fixed a couple of issues with External Output with Blackmagic cards where video output may jitter or lose audio on some systems. ** Please note we have a support request in process for an issue where the Quad 2 may lose audio on output. This appears to be a driver issue and we are working with BM on a fix. * Updated NDI to latest release. (Fixed bug where newer NDI software may only top half of image when being received by older software) * Updated Twitch API * Fixed issue with audio gain set on Master was double on recording and streaming * Image Sequences with sound effects will now stop at end of transition, to allow for sound effects that run for longer than the transition. * Upgraded Web Browser Input Chrome version to the latest. * Fixed bug where Web Browser Width/Height greater than vMix resolution would result in browser starting zoomed in. * Fixed bug where MP4 recordings may appear upside down if Output Format is set to xRGB32
* Added a number of improvements to Countdown feature in Titles: * 1. Countdown current time can now be changed manually * 2. Option to select which way the "stop time" is displayed * 3. ChangeCountdown shortcut function added that accepts absolute time to move the countdown to * 4. SuspendCountdown shortcut function that only pauses countdown vs PauseCountdown which Pause/Resume/Resets
 10 users thanked admin for this useful post.
17.0.0.90
* Fixed issue where Hardware Encoding on latest NVIDIA drivers would result in garbled output * When inserting items into a playlist, previous selection is now preserved * Improved performance of FFMPEG x264 recording preset and added a superfast option
vMix Desktop Capture for Mac has been upgraded to the latest version (17.0.0.70) to support the latest version of NDI needed to work with vMix 17.0.0.88 and higher.
17.0.0.91
* Updated NDI to fix a critical compatibility issue. This is a recommended upgrade for those using .88 and .90 * vMix Desktop Capture for Windows also updated to version 17.0.0.71
 3 users thanked admin for this useful post.
17.0.0.92
* Fixed bug with web browser input in .91 where some media formats would not play. * Fixed bug where RTSP Stream input was not working with Video Delay
17.0.0.99* Updated to latest version of NDI. Improved performance, and fix for quality issues with desktop capture. * Added support for MIDI Pitch Bend controls (detected as MIDIControlChange Note 1024) * Added support for MIDI controls that act as a Jog Wheel (such as CMD PL-1) * X-Keys XK-12 Jog and Shuttle support * X-Keys XK-12 Joystick support * Added additional fixes for laptops with NVIDIA Optimus. Should now work correctly across all Optimus laptops. * Shortened connection time when loading NDI inputs from preset * Fixed bug preventing SuspendCountdown from working correctly * Fixed bug for AAC decoding on RTSP streams with sample rate below 32Khz For more information on using MIDI and X-Keys controllers with Jog Wheel type controls see: http://www.vmix.com/help...vancedMIDIShortcuts.htmlvMix Desktop Capture for Windows and Mac now updated to 17.0.0.73 with a number of improvements as wellhttp://www.vmix.com/ndi/
 9 users thanked admin for this useful post.
17.0.0.100 * NEW Instagram support added to vMix Social. Search for recent media by Tag or Username. * Added tickbox for Keyframe Aligned in Streaming Quality settings to provide support for seamless bitrate switching. * Fixed bug with AAC causing Audio Error on some RTSP streams in Windows 10 * New Replay shortcuts added: ReplaySelectFirstEvent, ReplaySelectLastEvent, ReplayCopyLastEvent, ReplayCopySelectedEvent * MoveSelectedInPoint/OutPoint can now be assigned to a JogWheel Rotary Knob on MIDI controllers such as the behringer CMD PL-1
17.0.0.103 * Added Audio Only support for NDI inputs to reduce CPU usage * Added NDI output support for Webcams that use RGB32 format * Fixed a couple of issues with aspect ratio correction when bringing in NDI sources such as from Desktop Capture (If NDI sources from older Presets look skewed, reset the Zoom to 1 in Input Settings -> Position) * Fixed NDI inputs sometimes loading from presets without a source selected * Fixed vMix Social bug where Facebook Login may not work where already logged in from Internet Explorer. * Fixed flicker when changing NDI sources * Fixed Channel Mixer and Headphones control not working with List Input * Fixed crash when converting some capture cards into NDI outputs * Fixed incorrect height issue on some virtual sets * Fixed bug when changing master aspect ratio in settings
17.0.0.105
* NEW Total CPU Usage Meter in status bar! This is based on the CPU reporting in the Windows "Performance Monitor" metrics and may differ from the numbers reported in Task Manager.
* Added support for Stinger Transitions in the PlayList feature * Updated Web Browser Input Chrome version to latest version to fix some bugs and improve performance * Fixed potential bug with Optimus support under Windows 8.1 * Fixed problem with X-Keys devices on systems with a lot of USB devices in use
 11 users thanked admin for this useful post.
Zetor1980 on 7/17/2016(UTC), stigaard on 7/17/2016(UTC), corporatejames on 7/17/2016(UTC), ON.tv Channels on 7/17/2016(UTC), RoboST on 7/17/2016(UTC), nethaaji on 7/17/2016(UTC), sinc747 on 7/18/2016(UTC), madness on 7/18/2016(UTC), BETech on 7/26/2016(UTC), Amokka on 8/6/2016(UTC), bcolgate on 10/14/2016(UTC)
17.0.0.106
* Added two new Replay shortcus: ReplayUpdateSelectedInPoint and ReplayUpdateSelectedOutPoint * Improved smoothness when changing slow motion speeds during Instant Replay playback * Fixed issue with MultiView cropping of a chrome keyed source using Medium or High anti-aliasing * Fixed error when closing vMix if an X-Keys controller has been unplugged * Fixed display bug with collapsed inputs after changing settings
17.0.0.107
* Much reduced CPU usage when using Hardware Encoder (GPU) with streaming and latest NVIDIA drivers are installed. (368.81 or higher)
* Added support for showing/hiding cursor when capturing displays using Local Desktop Capture. (Note: this does not apply when capturing individual windows)
* Fixed bug when using Adobe Premiere with the NDI plugin to send alpha channel graphics and videos to vMix * Fixed rare bug where saving a preset at the exact moment as the automatic "Last" preset may cause inputs to double up * Fixed issue where appending a preset with Replay inputs into an existing session with Replay resulted in an input that could not be closed. Replay inputs now correctly load into offline mode as multiple Replay sessions cannot be open at the same time.
17.0.0.108
* NEW Added support for Continuous Facebook Live streams, these are for 24/7 streams which means Facebook won't publish them as videos when complete or notify users. * NEW vMix Social 3.0 included with support for removing URLs from Tweets and fixes for Facebook posts with more than 800 comments such as Facebook Live videos. * Fixed bug with undocked Audio Mixer not updating when adding new inputs or loading presets * Fixed Stingers using Image Sequences with audio, when called from MIDI or the Web Controller * Changed OnCompletion trigger to also work for Overlays. Also added OnCompletion support to image sequences. * Ctrl+A now works in the Title Editor
17.0.0.109
Fixed a few bugs relating to RGB sources appearing upside down in a couple of cases:
1. When recording from some blackmagic devices where video format is set to RGB32 2. When sending capture inputs out via NDI where the underlying format is RGB (such as webcams) 3. When using MultiCorder with FFMPEG and RGB
17.0.0.110
Fixed a couple of bugs with vMix Replay:
* Under heavy load, replay may not split the recording at 20 minute intervals leading to an Index error. * If an Camera Input is reset, vMix Replay will now correctly reconfigure the source by stopping recording, clicking the cog icon then clicking OK.
17.0.0.111
* Fixed countdown value not appearing in the API/scripting * Added support for Deltacast cards
 4 users thanked admin for this useful post.
