Hardware Compatibility
Elgato Helper Device (unavailable) Elgato HD 60S
Hello, I just bought the Elgato 60S. But when I try to use this as a camera I get the error message Elgato Helper Device (unavailable) : AddNewInput Capture Device Is Not Supported, Device Reported the following: Video Capture 32595559-0000-0010-8000-00aa00389b71 I installed the driver and software that was suggested and restart the computer. But I got the same 'camera' Anyone with suggestions? Rgds, Daan videologic attached the following image(s):  Fout elgato.png (180kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
Thanks: 211 times Was thanked: 13 time(s) in 12 post(s)
I just bought the same device and am having the same experience, any progress on this issue?
I disconnected the internet (in case the drivers tried to load automatically), uninstalled the driver (in device manager and add/remove programs), rebooted and ran the Download Game Capture 3.5 Beta software setup.
Once it was completed running, I launched it and made sure the device worked there and then closed the Game Capture software.
Then I launched vMix and selected an input, this time the actual device was listed (along with the same previous elgato helper...(unavailable) listing), so I just selected the device and it worked with no issues.
Hope this helps anyone else having this issue
