Crienz90
#1 Posted : Friday, June 3, 2016 5:48:10 PM(UTC)
Crienz90
Salve vorrei acquistare questa scheda video della blackmagic ma vorrei sapere se funziona con vmix 17, se qualcuno la usa già, ho un Hp Intel i7 con 16gb di ram 4gb scheda grafica e 1tb hard disk grazie
#2 Posted : Saturday, June 4, 2016 10:14:27 AM(UTC)
@ Criens90
Although it doesn't show up on the supported hardware page:
http://www.vmix.com/soft.../supported-hardware.aspx
I am quite sure it works with vMix.
Similar Topics
Intensity Shuttle USB 3.0 freezing (General Discussion)
by mjbrad11 9/17/2019 9:52:10 PM(UTC)
ASRock B85M Pro4 + Intensity Shuttle USB 3.0? (Hardware Compatibility)
by Ph0en1x 8/23/2017 9:55:33 AM(UTC)
Blackmagic Intensity Shuttle USB 3.0 Won't Work (Hardware Compatibility)
by abdonsara 7/2/2014 10:56:49 PM(UTC)
