How to set up password for Web Controller
Hello to all. I want to control vmix from global network, and want to control it only by password. How its possible to enable it?
Cheers Denis
I don't think that is necessary---
In order to do this you are going to have to forward incoming traffic on your router.... you could control it there with some fancy tricks.
Instead, I would change the port of the webserver to something besides port 8088. This will prevent most automated scanning.
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
VPN with authentication is the only proper way of doing it....
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
You can't enable a password out of the box. I have not tried it, but this should work: Use nginx (http://nginx.org/en/download.html) as a reverse proxy on your vMix computer. There is also a Windows version for download. You can use this guide: http://www.robustpercept...o-prometheus-with-nginx/For generating the htpassword-file use this link: http://www.htaccesstools.com/htpasswd-generator/To start nginx as a service: http://oss-world.blogspo...ndows-service-using.htmlAs last step you have to add a firewall rule on your local windows firewall which blocks incoming traffic except localhost/127.0.0.1 on port 8088 (default vMix port) to your vMix computer. Now it's not possible anymore to access the vMix web interface directly, only through the reverse proxy. Regards
Was thanked: 7 time(s) in 3 post(s)
 1 user thanked cg4162345 for this useful post.
