Blackmagic Duo 2 no video output
Joined: 4/12/2014(UTC) Posts: 4  Location: Trinidad Thanks: 2 times
Hi, I recently got installed the blackmagic DUO 2 card and configured the card 3 input 1 output. The 3 inputs are working but only getting black on the output. What further setting do I have to make to get an output signal.
Joined: 6/2/2016(UTC) Posts: 40  Location: Everett, WA Thanks: 11 times Was thanked: 3 time(s) in 3 post(s)
I'm installing the same card today. I'll let you know how it goes here.
I was able to get output via the Decklink Duo 2 card, I had to select each of the available devices in the external output settings, one by one, until I found one that worked. Oddly, it was 'Decklink Duo (1)1' that worked; but it's also 'Decklink Duo (1)1' that is my input for camera 1. I have to say that I don't understand how this card is routing the in's and out's.
From bottom to top in normal duo mode:
REF SDI in 1 SDI out 1 SDI in 2 SDI out 2
In 4 input mode:
REF SDI in 1 SDI in 3 SDI in 2 SDI in 4
So it's a bit confuing, but when you know you know.
 1 user thanked Mathijs for this useful post.
Mathijs wrote:From bottom to top in normal duo mode:
In 4 input mode:
So it's a bit confuing, but when you know you know. So, can it do 3 in/1 out?
