NiBTour
#1 Posted : Thursday, June 2, 2016 3:23:57 PM(UTC)
NiBTour
Seems like a silly question but browsing the web and BM site I haven't really haven't found an answer yet. The answer I did find was the only option that didn't completely work. Anyway I have 4 options for each of the following:
Blackmagic WDM Capture (1-4)
DeckLink Duo (1-4)
Decklink Video Capture (1-4)
The answer I kind of found was use the Video Capture but when I select that option no audio comes through. The other two options audio does come through but delayed about 60ms. I think I figured the delay portion out so no worries there but just wanted to know which one I should use. Some have different options and the Decklink Duo option has none but seems to work the best as of now.
Latest version on both vMix and Decklink as of today.
thanks!
Maximus
#2 Posted : Thursday, June 2, 2016 4:04:56 PM(UTC)
Maximus
I have a Decklink Quad and the inputs I use are labeled Decklink SDI 1-4. Those are the ones I used. Make sure the settings match the camera output, else you won't see an input.
Maxi
