Feature Requests
External Output to Include vMix Audio
I have done a (somewhat) exhaustive search through the FR section and could not find this. My apologies to the author if someone else has already made this FR.
In the same way the vMix NDI Output carries audio & video to an NDI-compatible destination, can the External Output also be made to carry the Master Audio Output? Very handy (and less cumbersome) for output to Skype and others.
Remember that the vMix Audio Outputs go to "speakers" and thusly cannot be used as "microphones" in Skype and others.
- Tom
Tom, this is all ready possible if you are outputting externally to a device such as a BM card. I think I understand that you might be referring to the VVD output rather than the external render. My understanding of that is that it uses the Windows subsystem which might limit the options. It might be nice however to be able to select the audio output device on the external outputs as is currently the case when selecting the external renderer.
Yes, I am referring to the External Output as opposed to a physical output device like the BM card.
And yes, what I want is a VAD -- a Virtual Audio Device that can be a vMix Audio Output seen by Skype and others as an Audio Input aka microphone.
Feature Requests
