No 1080p25 video input if the systems settings is 1080i50?
Thanks: 38 times Was thanked: 24 time(s) in 20 post(s)
today I ran into a strange thing. Probably this was my mistake, or maybe this is a limitation in Vmix. So, the Vmix master frame rate was set up to 1080i50. I used Blackmagic Decklind Quad card, and the latest drivers was installed (with the latest Vmix version).
I received 1080i50 signals without any problem. But if I tried 1080p25 signal format, I can't see anything in Vmix. Otherwise the sugnal was ok in the mediaexpress, and it clearly indicate to 1080p25 format.
So the question is: is this a Vmix limitation? I can't use 1080p25 inputs with 1080i50 master frame rate?
Thank you!
Okay, seems to be it was my fault. I used WDM capture input, that was the problem. Today I tried with Decklink input and now it works.
