carlosowusu
#1 Posted : Saturday, May 28, 2016 10:07:32 AM(UTC)
carlosowusu
Hello
Sorry if this has been asked before but I would like to know if I can use my Decklink Extreme 4K to
do internal keying with VMIX? When I add an input, I can't use External Output? Am I doing something
wrong? Or do I need another card for External Output?
Mathijs
#2 Posted : Saturday, May 28, 2016 10:54:59 AM(UTC)
Mathijs
Don't know why this happens, but the card should be able to input and output at the same time.
Matt Jefferson: All of the Decklink and Ultrastudio with the name or title with "4K" are able to be provide input and output at same time. The Decklink SDI 4K, Studio4K, 4K Pro, 4K Extreme (6G) and 4K Extreme 12G are all able to do support full duplex. Also, the Ultrastudio 4K and 4K Extreme (when shipping) are full duplex. To confirm on above products, the inputs and outputs can be used at same time
carlosowusu
#3 Posted : Saturday, May 28, 2016 11:33:55 AM(UTC)
carlosowusu
But in this case it doesn't. It's always used up by the input. If there were an option that I could
check somewhere to enable Internal Keying that would be great. Or maybe I have to just say not supported?
Len56
#4 Posted : Sunday, May 29, 2016 2:00:08 AM(UTC)
Len56
Go in to the Decklink control panel and see if there is a setting in there that will allow you to set the Decklink Extreme 4K up to do in and out at the same time.
