mkobzar
#1 Posted : Saturday, May 21, 2016 2:26:35 AM(UTC)
mkobzar
This time I install some tv's vertically on columns - 9:16 aspect, it is not so comfortable in vmix. Can you make button to rotate master, preview and input screens. It not for output, just for comfortable work in vmix.
madness
#2 Posted : Saturday, May 21, 2016 11:29:07 AM(UTC)
madness
Might I suggest the format is good as is if you simply just rotate your vMix monitor as well. That would also continue to provide the best use of space on that monitor. If you make those inputs, preview, and output Protrait mode, then there would be much more wasted workspace.
Now I could see this being more beneficial if you had mixed content you were delivering, but then, it's hard to deliver that landscape content to output monitors that are in portrait as well.
For what you are doing, I would rotate the main display to match your output displays. And the greatest thing of all, is that can be done without much effort, now.
mkobzar
#3 Posted : Sunday, May 22, 2016 1:26:34 AM(UTC)
mkobzar
Thank you for Idea. But I see some problems.
1. If I rotate screen, I rotate vmix and windows interface too.
2. Sometimes I use sound and picture control.
Anyway, it is still a matter of habit.
desmar
#4 Posted : Sunday, May 22, 2016 1:59:45 AM(UTC)
desmar
Canada
Refer to this post on screen rotation/sizing...
http://forums.vmix.com/default.aspx?g=posts&t=6201
mkobzar
#5 Posted : Thursday, July 21, 2016 9:47:25 PM(UTC)
mkobzar
It is not a solution. I need rotate i/o screens, not interface.
desmar
#6 Posted : Friday, July 22, 2016 3:31:54 AM(UTC)
desmar
Canada
You can rotate the input and preview,
- Select input
- Select cog wheel (bottom Right below input window)
- Select Postion in config
- Select Main
- Select Rotate Z and rotate screen to desired view.
mkobzar
#7 Posted : Friday, July 22, 2016 3:52:42 AM(UTC)
mkobzar
I mean this rotate. aspect 9x16
desmar
#8 Posted : Friday, July 22, 2016 5:58:11 PM(UTC)
desmar
Canada
Ok, you want to be able to have landscape mode as output...
Would be nice to have portrait and/or landscape mode or
even a combo of both would be nice..
Multiple outputs/Streams, 1 Portrait and 1 Landscape etc..
+1 for that feature....
Guest (4)
