Feature Requests
vMix Quad Display & Full-screen (Resolved)
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
I use a Gigabyte 750TI with 4 32" Samsung TV's as Monitors running at 1080p and 1 32" Samsung TV's as Monitors running at 1080p as an external screen via Blackmagic card.. This is my setup, Screen 1 Main vMix Screen Screen 2 vMix Audio Mixer Window Screen 3 vMix Multiview Screen 4 vMix Desktop Capture Screen Screen 5 vMix Program Output Via Blackmagic Card But there is a software solution that works good... Allows to split each screen in different configuration you like... Called Display Fusion.... http://www.displayfusion.com/
BETech, I really like what you have done! And we are very curious about if the Fullscreen issue can be taken care of. It was a big improvement for us to go for 21:9, your quad on a 4K monitor seems even more promising.
I think TV monitors generally have a slightly longer latency from the TV's input connector (not to be confused with response rate), when compared to PC monitors. Although I don't think that's a major problem for us. One also needs to consider the TV's "image enhancement" settings.
Do you mean that Virtual Display Manager and SplitView are mutually exclusive, or should they be used in a combination?
I'm not exactly clear on how UHD displays deal with HD resolutions but certainly the aforementioned allocation of screens within quadrants or thirds of the UHD screen would be a most welcome feature option I am sure.
+ 1
Joined: 1/13/2010(UTC) Posts: 5,337  Location: Gold Coast, Australia Was thanked: 4740 time(s) in 1626 post(s)
BETech, Take a look at the Display tab in Settings. It has many options to configure the fullscreen output, including the Position option that allows you to specify exact screen coordinates to display the output. http://www.vmix.com/help17/Display.html
Feature Requests
