GeorgeR
#1 Posted : Thursday, May 19, 2016 10:55:15 PM(UTC)
GeorgeR
Was thanked: 30 time(s) in 28 post(s)
Hello vMix,
Small request. Might you be able to change the headphone volume level adjustment from a dial to a small slider? I turned the volume down using the dial and almost never got the volume turned back up.
Thanks for the consideration.
~GeorgeR
Mathijs
#2 Posted : Tuesday, May 24, 2016 8:48:51 PM(UTC)
Mathijs
If you get the mouse onto the button and click left mouse, you can drag mouse up or down to set the volume quite easy. Don't try to rotate it. It already behaves as a fader. ;)
thanks 1 user thanked Mathijs for this useful post.
GeorgeR on 5/24/2016(UTC)
GeorgeR
#3 Posted : Tuesday, May 24, 2016 10:13:40 PM(UTC)
GeorgeR
Mathijs, thanks for the tip but I don't think I'll be tinkering with that function anymore. Was just playing around in vMix to see what did what?
Thanks again.
~GeorgeR
