Play Audio File on Image Overlay (and then fade audio as overlay fades)
Hello, I am trying to get this to work, but haven't found the correct command in trigger. Does anyone know how to do this? Is Trigger the correct way to have audio come in and out as images are overlayed? Thanks, Scott
@ cituofathens
Yes, you can use "Triggers" to fade audio, but not when used on an 'Overlay' (it will not activate in that capacity). Also, you will likely have to add several triggers in sequence to achieve a real 'Audio Fade' or fade out. There is no single trigger command (as of yet) to do this, each command or function you implement will only alter the audio to a specified level.
