2 Pages<12
melody
#21 Posted : Thursday, August 30, 2012 5:18:39 AM(UTC)
Rank: Guest
Groups: Guests
hi dundurs,
i use the onboard Realtek ALC1200 8-Channel High Definition Audio device in my Asus P6T and i need to delay the stereo line input in vmix to sync it with my hdv sources.
isn`t the delay that you are talking about related with asio feature? maybe you can take a look on it.
regards,
melody
www.espiritosanto.cc
dundurs
#22 Posted : Thursday, August 30, 2012 8:29:55 AM(UTC)
dundurs
Was thanked: 46 time(s) in 23 post(s)
melody wrote:
hi dundurs,
regards,
melody
I believe, if you want to delay audio, you should use vMix audio delay feature. In my case I dont want to delay audio and Im looking for a solution for this problem whic came up relatively recently.
Dundurs
#23 Posted : Thursday, August 30, 2012 8:40:40 AM(UTC)
There have been no changes to the audio input functionality since v3.
On the audio recording side of things v4 introduced the "vMix Audio" option to record just the audio from vMix but if the delay shows up
outside of the recording then my guess is the soundcard driver itself is introducing some kind of delay.
silverhawk184
#24 Posted : Sunday, September 2, 2012 10:36:55 AM(UTC)
silverhawk184
How does one setup the setText feature? I tried via the API and settings a keyboard shortcut via the GUI, but neither show up on the video feed.
silverhawk184
#25 Posted : Sunday, September 2, 2012 11:02:16 AM(UTC)
silverhawk184
Also, Is there a way to implement a global audio input. I have a multi-camera setup, and have to dedicate one input to my soundcard, which leaves me with only 3 inputs for 2 cameras and projector. Using this method I have to make sure the soundcard input's audio box is always green when I change cameras.
melody
#26 Posted : Sunday, September 2, 2012 5:47:13 PM(UTC)
Rank: Guest
Groups: Guests
hi silverhawk184,
that is simple to do:
1. go Settings
2. open audio tab
3. uncheck "Automatically mix Audio"
after that, just need to associate your audio device to one video source or symply add that audio source as input.
regards,
melody
#27 Posted : Sunday, September 2, 2012 10:34:49 PM(UTC)
The latest test version has now been released to the public. See the thread below for further discussion:
http://forums.vmix.com.au/default.aspx?g=posts&t=491
2 Pages<12
