smudge1977
#1 Posted : Monday, May 9, 2016 6:14:00 PM(UTC)
smudge1977
Was thanked: 4 time(s) in 1 post(s)
I have seen the FAQ about a black web browser input when you have an nVidia graphics card
However the machine in question has Chrome installed and an Intel HD graphics. Have tested the site on another machine with vMix 17 and it is fine.
So must be something to do with the Intel HD 4400 graphics I assume...???
Chrome Version 50.0.2661.94 m (64-bit)
Help please....
Cpilcher
#2 Posted : Monday, May 9, 2016 7:44:44 PM(UTC)
Cpilcher
Someone else was having trouble with Chrome. The Admin said it was an update with chrome that caused the problem. I'm not sure if it was fixed yet...
Chuck
http://forums.vmix.com/d....aspx?g=posts&t=6203
smudge1977
#3 Posted : Wednesday, May 11, 2016 5:52:18 PM(UTC)
smudge1977
Unfortunately that relates to desktop capture
I am trying to use the new web browser input type
Also this laptop is running the same version of Chrome as the machine that does not work - this is why I think it must be to do with the Intel graphics card...
Cpilcher
#4 Posted : Wednesday, May 11, 2016 6:54:35 PM(UTC)
Cpilcher
What system are you running on. I can test the input on my setup and see if it gives the same result.
Chuck
smudge1977
#5 Posted : Friday, May 20, 2016 6:04:30 AM(UTC)
smudge1977
The machine does not launch the CefBrowserInstance.exe
If I look on a working machine you see one of these processes running for each web browser input but on the broken machine nothing
I have given everybody full control of the vMix install folder and sub directories and still the CefBrowserInstance does not seem to get launched or if it does it fails and does not stay running.
I have attached the system information report
File Attachment(s):
Whitgift SysInfo.txt (2,147kb) downloaded 3 time(s).
#6 Posted : Friday, May 20, 2016 1:00:47 PM(UTC)
Does the following article help?
http://www.vmix.com/know...-nvidia-optimus-graphics
smudge1977 on 5/20/2016(UTC), vadim_d on 2/6/2017(UTC)
smudge1977
#7 Posted : Friday, May 20, 2016 5:21:59 PM(UTC)
smudge1977
Hi Martin
thanks for the update - i had seen that article but i can not find anything like this for the Intel(R) HD Graphics 4400
I have tried on another machine that has AMD Radeon HD 8400 and that works fine
Any ideas please....
Keith
smudge1977
#8 Posted : Wednesday, May 25, 2016 5:18:15 AM(UTC)
smudge1977
YOU NEED SPEAKERS OR HEADPHONES PLUGGED IN!!!
Try running the cefbrowser.exe from the browser folder and see if it errors
Thanks for your help remotely on this Martin :)
