Joined: 3/17/2013(UTC) Posts: 235  Location: Indiana Thanks: 95 times Was thanked: 30 time(s) in 28 post(s)
vMix 17.0.0.77 Windows 10x64 computer Even when vMix is not running, I can not pull other cameras into Skype (Logitech c920 or a HuddleCamHD). All that shows are vMix camera options (vMixVideo and vMix External 2). For most of us that would not be an issue as we would probably use vMix for the Skype camera. Just seems odd that I can not use any other cameras when vMix is completely shut down. Checked the Task Manager. vMix is nor running in the background. Rebooted the computer and shut the cameras down. Still could not attach either the Logitech c920 or a HuddleCamHD to Skype. Await your answer here in Indiana (LOL). Have a great day! ~George
Joined: 3/30/2014(UTC) Posts: 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
Hi George,
Maybe its Windows 10 causing the problems, have you tried useing the cameras on a non windows 10 machine like windows 7 to see if you get the same problems, I have a C920 and had no problems with it but I am useing windows 7 64bit machine.
I have not tried the C920 in Skype yet but I have had it working in vMix, one other thing are you using the latest driver fo your cameras?
George, in the Sykpe video options, you need to scroll up or down in the camera selection list to see the Logitech
Thanks Everyone, Different day, different outcome.
Opened vMix and un-checked all NDI options. Started Skype. All cameras work fine including HuddleCam. Opened vMix back up. Re-checked all NDI options. Opened Skype and all cameras still work in Skype. So, don't know what the issue was last night but everything works great now?
Thanks Again, ~George
Well done George, glad you got it to work.
