Titles - Scoreboard - HELP!
Joined: 8/21/2012(UTC) Posts: 194  Location: Cordoba - Argentina Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Hi! Im writing because i'm editing the scoreboard, but i have a problem. I'm modifying the ScoreBoardHD2.xaml file but when i make a change (my scoreboard is an image larger than the original, but always respecting the original size of the file), vMix doesn't load the picture (the numbers and labels are loaded but not the pic).... what i'm missing? Thanks!!!!!!
Joined: 1/13/2010(UTC) Posts: 5,324  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Please send through a copy of the image and the modified xaml file. My guess is the filename is not pointing to the correct path.
Martin vMix
Hi Martin, first of all, thanks for answering! I dont know how to upload here the pics so see here: Before modifyingAfter that, i have just modified the file ScoreBoardHD2.xaml.png (sorry, i forgot in the first post to put the "png" extension... my mistake). The result after editing the file: After!No changes in the quality, in the size, or filename. I think i'm missing something, and i'm really not familiarized with the xaml files so i'm learning... hope not asking a basic thing. Sorry if yes... Regards!!
Could you upload a copy of the modified png? I suspect it is a in a strange file format XAML doesn't recognise.
Martin vMix
Hi Martin! The file modified is this but obviously is not the final. I was trying but when i saw the problem i didnt continue working. Thanks!! Regards
Due to the slightly different PNG format you will need to specify a width and height in the xaml file.
Change:
<Image Canvas.Left="0" Canvas.Top="0" Name="Image1" Stretch="Fill" Source="ScoreBoardHD2.xaml.png" Opacity="0.9" />
To:
<Image Canvas.Left="0" Canvas.Top="0" Name="Image1" Stretch="Fill" Source="ScoreBoardHD2.xaml.png" Opacity="0.9" Width="1920" Height="1080" />
Martin! Hi!!
You were right... the problem was solved changing that lines... Thanks!!!!!!!
Regards
Gustavo
Joined: 6/11/2012(UTC) Posts: 39  Location: jakarta Thanks: 34 times Was thanked: 12 time(s) in 7 post(s)
 hi martin, on the scoreboard title, you can add a timer? This will be a perfect software. eg, at football games, 2x 45-minute running time and a total of 90 minutes. also included late in regulation when we set the time in the middle of the match. I hope these suggestions can be taken into consideration. Thank you. regards,
We're planning on selling an add-on titles packs which will include many additional templates including scoreboards with countdown timers.
The first title pack will be around $30 for 30 titles and is due out in the next couple of months.
Martin vMix
Thanks: 19 times Was thanked: 4 time(s) in 1 post(s)
Hi Martin
I really need count down / up timers that can do 90 minutes and not 1:30
Please tell me this is going in soon :)
Thanks for a great product
Keith
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ smudge1977
Not sure why you've posted in this thread, but the timer already does what you request... It's just a matter of selecting the 'Display Format' to "mm:ss". Your 'Duration' is still "01:30:00" but the display will be "90:00".
Hope that helps some.
HEllo!
I have trial version 22.0.0.54 and i tried to get timer count up to 90 minutes. I read the instructions for previoius post, but i cant use display format mm:ss. Everytime when 59:59 should changes to 60:00, timer starts at 00:00
When i use df mm, everythings works fine. ???
This is very important issue, cause i will use vmix in the future on the soccer games.
regards,
-Tommi-
Joy, how r u? Can send a screenshot of the title clock setup? Best regards
You are lucky, my clock does not work....for some unknown reason, it does not...I had to change the HD in my system, and loaded the trial version, only to find that the clock is not working, and GT titler does not work in 32 bit ..I tried because the 64 bit installation seems to be acting strange....starts sometimes, and is suspended in another instance......so I do not know why....I may have to try a new HD to see if this one is heading for the garbage....had this happened before with an older system....I just want to do some stuff with the GT Titler....
Hi Guztavo! My setup is dell 5530 precision Core i7-8850H, 32 Gt, 1 Tt SSD Nvidia Quadro P2000 Here is some pictures:  mm mode.JPG (183kb) downloaded 0 time(s). mmss mode.JPG (200kb) downloaded 0 time(s). settings changes to 60.JPG (190kb) downloaded 0 time(s).mm:ss mode not working, but mm mode works fine? -Tommi-
