Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
You are doing a great job. I was thinking, maybe with your team list it can be very easy to work with soccer substitutes, yellow/red cards, goal scorer etc Easy dropdown of name and drop down of card Easy dropdown of player name in, easy dropdown of player name out With special graphics for each one :)
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
I use the WebClient class also, as i too was having issues with the WebRequest class....
Joined: 10/23/2015(UTC) Posts: 458   Thanks: 20 times Was thanked: 231 time(s) in 130 post(s)
@Siroki, that's goal of list: provide fast access to some data.
Joined: 9/1/2015(UTC) Posts: 128  Location: Ecuador Thanks: 2 times Was thanked: 16 time(s) in 12 post(s)
Hi @elgarf, excellent job with this app, I consult you sell this application to vmix or is only a test
@JAIRODJ, at now I don't sell this (just develop in free time, because it's interesting for me, I even don't plan to use it by myself), but think about it.
elgarf wrote:This topic is about vMixWpfScoreboardLoader and other useful apps for vMix, that I maybe write in the future. Feel free, to post there applications of that modules. GitHub repo of vMixWpfScoreboardLoader Hello, I would like to ask how do I run a DLL file that is used to control the scoreboard? thank you for answer
Hi.
Just load it as title, then it show open file dialog.
elgarf wrote:Hi.
Just load it as title, then it show open file dialog. ¨Thank you for answer. So I have tried. But the result was such that I hide the caption. Only a blank window (blank input). Furthermore, when I tried to load only the XAML file and graphic background was red only, not loaded with PNG graphics. I'll try it and it was in a newer version Vmix.
There are some limitations about graphics, so you need to tag element with graphics. I'll post example later.
Don't you see vMix UTC? It's the next step in my development, but still not ready. It can do all that can Scoreboard Loader, and many more else.
elgarf wrote:There are some limitations about graphics, so you need to tag element with graphics. I'll post example later.
Don't you see vMix UTC? It's the next step in my development, but still not ready. It can do all that can Scoreboard Loader, and many more else. I wanted to try some free solutions. Vmix UTC is not free, is it?
I don't plan to make free version, but maybe I did:) something with just text field and scoreboard widgets.
Don't you see vMix UTC? It's the next step in my development, but still not ready. It can do all that can Scoreboard Loader, and many more else. So I tried it on another PC with powerful graphics card and it works. So it is really a problem in the graphic card. Can I have another question? How can I get my time started and stopped from 00:00 to 45:00 minutes? Somehow I do not listen;)
I can answer you later, now I'm at a gig:)
elgarf wrote:I can answer you later, now I'm at a gig:) Ok, thank you
duck130883 wrote:elgarf wrote:I can answer you later, now I'm at a gig:) Ok, thank you Hmm. Looks like I made stopwatch only with invert, e.g. you need to stop it manually (or change source code).
