impressed but also wondering about some functions!
Hi, I just installed your program on my computer. a Gigabyte GA-880-GM-USB3 with AMD Athlon(tm) II X4 640 Processor with W7/64 and onboard ATI/AMD Radeon HD 4250 and although you did not mention anything like this in your hardware requirements i am pleased to say that it all seems to work! Until now, money well spend!
But i have tried to figure out how to work with your chroma keying. I do understand how to select a specific or preset color and change - if needed - the colors, but until now I could not make a real key because I do not know how to set the background.
Browsing through the manual (which has - in downloaded version has an issue in itself: the index is visible but no content...) I cannot find anything that relates to this.
Please help me here, how do I choose a background behind a keyed input ( I use Decklink Duo)?
Thanks,
Rob
ahh, I found out now, enabling the little number 1 on the preview pane makes it happen.... great!
Thanks for this program!
Joined: 8/4/2012(UTC) Posts: 129 Location: the Netherlands
if you think that is great experiment a little with the 'multi view' tab in any input settings pane :)
m@IK
