vMix Audio to Newtek 'NDI Connect' : Sound
I am confused. Is your issue with Connect or with the vMix NDI implementation? I have been able to send audio and video using NDI quite happily using vMix to another vMix, and Desktop Capture to vMix and Newtek Scan Convertor to vMix, etc.
NDI Connect will bring the video and audio in from a camera. I would assume that to make vMix a source for it you use the external 1 or 2 function. Connect would probably not pick up audio in that scenario.
Joined: 1/13/2010(UTC) Posts: 5,322  Location: Gold Coast, Australia Was thanked: 4726 time(s) in 1618 post(s)
You don't need to use NDI Connect to send the vMix output over NDI, simply go to Settings -> External Output / NDI in vMix and tick the box to enable the output and it will show up as an NDI source.
Martin vMix
i got a different problem when i use vlc to output to NDI ( and have audio en video set to NDI out in vlc ) i only get video no audio...
LG wrote:i got a different problem when i use vlc to output to NDI ( and have audio en video set to NDI out in vlc ) i only get video no audio... You have to set both the video and the audio plugins in VLC.
