Hardware Compatibility
great machine & capture deal in the US
Joined: 5/26/2013(UTC) Posts: 148  Location: Houston, TX, US Thanks: 28 times Was thanked: 6 time(s) in 6 post(s)
MicroCenter POWERSPEC G416 $1200: Intel Core i7-6700K Processor 4.0GHz Microsoft Windows 10 Pro 64-bit (7 downgrade too) G.Skill 16GB DDR4-3000 RAM 2TB 7,200RPM Hard Drive 256GB Solid State Drive NVIDIA GeForce GTX 970 CoolerMaster EVO Hyper 212 Cooler EVGA 500W 80+ Power Supply ASRock Fatal1ty Z170 Gaming K6 Motherboard
Blackmagic Decklink Duo 2 $500 4 SDI inputs in one card.
just add vMix and monitors
screamin'
Joined: 3/7/2012(UTC) Posts: 2,684  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ HWL
Specs look decent, I'm not as familiar with ASRock but the reviews look good, personally, I would prefer a beefier Power supply and a case with handles. Also, re-check the specs on the Decklink Duo, it's 2 In and 2 Out AFAIK, not 4 In.
decklink duo2 just released...even has regular sized BNCs.
this particular rig is going into a fixed install. Great video graphics card, fast CPU.
Thanks: 3 times Was thanked: 10 time(s) in 10 post(s)
They've done with the Duo what they did with the Quad - the v2 cards have four or eight channels which can either be all inputs, all outputs or any combination.
I can buy them for under $470... and BM just came out with SDI and HDMI mini converters for under $85 each
The documentation on the new Decklink Duo is still ambiguous, but given that the Quad 2 is now 8 in/out, it wouldn't surprise me that they did the same for the Duo.  Ice
