probably not directly vMix problem/related
watching a stream created with vMix I notice a narrow band ( right side) showing teared video (more like copied pixels streched to edge of frame)
I have experienced that on a recording too( dont know if it was visible in the vMix windows before the recording) be it was at the bottom then.
any ideas what this is a sign of ?
see bottom (cropped right lower part of frame) doggy attached the following image(s):  tear.png (435kb) downloaded 17 time(s).You cannot view/download attachments. Try to login or register.
