ask
#1 Posted : Friday, April 8, 2016 1:33:14 AM(UTC)
ask
Hi. Am really liking the ability to title each category, however they are global. That is when you change presets for a different event, the categories are as you set them up for the previous session. This is OK if you are just producing the same type of event but if you switch from a sporting event to a conference to or to a talkshow you would logically use different categories. Therefore it would work well to save the categories with each individual preset rather than as a global setting. Regards. Andrew.
#2 Posted : Friday, April 8, 2016 5:47:19 AM(UTC)
Was thanked: 4801 time(s) in 1648 post(s)
The category titles are saved in each preset and will be restored when it is loaded.
However vMix will retain the last used title names if no preset has been loaded yet as well.
ask
#3 Posted : Friday, April 8, 2016 10:54:32 PM(UTC)
ask
Thanks Martin. Yes all working as described. The trick is to load a "new" preset, then open a "saved" one to see the behaviour. I had not been resetting to default before testing. My mistake.
