Hello! We usually use Decklink Monitor with vMix like output. Sometimes but not often the video from Decklink Monitor ports started blinking. Sometimes we couldn't get video out from Decklink via vMix. All output parameters in vMix and Decklink I didn't change for this reasons. Then I noticed that drop frames increased very quick in recording information window for Virtual2 after I switched on the External button and send output to Decklink Monitor. See attached screenshot. Drops appeared even if I didn't start the recording. Is it bad? Could it be the consequence of poor performance or bad compatibility vMix and Decklink Monitor? Has anyone similar problems with Decklink Monitor?
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 756
A complete guess at this from a newbie, could it be that the source is interlaced or something?
The info seems to indicate a framerate problem
