Hi, I'm new to Vmix. Can I just check a setting with you all?
In Settings / Performance the Graphics Adapter box has 'Default' selected and underneath it it says " In Use: NVIDIA GeForce GTX 970" Is this correct or do I need to select one of the two NVIDIA GeForce GTX970 options in the drop down menu instead of Default?
Also, are there any drawbacks to have 'Low Latency Capture' selected?
Thanks, S
Joined: 3/30/2014(UTC) Posts: 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
HI Squier,
On the help page for vMix it says this:
Low Latency Capture
This will reduce the latency of Camera inputs by approximately one frame. This will substantially increase the load on the graphics card and may lead to dropped frames under heavy load. Hope this helps.
By the way where are you in the UK i'm in the south east of England.
