Grimble
#1 Posted : Thursday, August 9, 2012 6:57:11 AM(UTC)
Grimble
I'm trying to set up an eSports style webcast with multiple "cameramen" who send me an RTMP stream. I'd like to be able to do instant replay on each input stream, but the Video Delay input only allows me to select "Output" as the source. The documentation seems to indicate that I should be able to use any input as a source, am I missing something?
Thanks!
Grimble.
#2 Posted : Thursday, August 9, 2012 8:22:44 AM(UTC)
Apologies if the documentation isn't clear.
It mentions "The Video Delay Input allows you to select a custom delay to the Output or a Capture Input"
So the flash input is not supported for video delay at this time.
Grimble
#3 Posted : Thursday, August 9, 2012 8:42:43 AM(UTC)
Grimble
Aaaah, fair enough then! as I'm aggregating the rtmp streams on a local server first anyway, so I'll see what options I have to output the streams from there as some sort of virtual camera to then use as Capture devices in vMix.
Thanks!
Grimble.
