Joined: 1/13/2010(UTC) Posts: 5,366  Location: Gold Coast, Australia Was thanked: 4788 time(s) in 1643 post(s)
Hi Manuol,
What graphics card do you have? Sounds like you probably need to upgrade it.
Martin vMix
Hi Martin,
IT WORKS !!! I had to change "Settings => Performance => Video renderer" from "VMR9" to "EVR". I thought I had tried it before, but maybe I had modified something else at the same time, or not correctly restarted vMix after altering the parameter (I'm sorry, I tried so many conifgurations, I'm now not really sure of what I tried or not).
What I don't understand, is why v2 works fine with "VMR9" option, and v4 don't... but v4 + EVR is OK. Now I can test vMix ;-) !
Thanks for your work, and your concern about my problem.
Emmanuel
PS : I do not delete my initial post, in case the problem description could be useful to someone.
