Joined: 6/16/2015(UTC) Posts: 193   Location: Milton Keynes, UK Thanks: 10 times Was thanked: 53 time(s) in 27 post(s)
Is VMIX 17 going to support NDI output channels? or Just Input?
I am keen to test NDI with Alpha from a CasparCG to VMIX will VMIX 17 support NDI with Alpha, or will we need to use 2 x NDI channels to 2 x VMIX inputs and use VMIX key?
What are the anticipated resources required for each NDI input over say and SDI input? i.e CPU bandwidth, Memory use, Network bandwidth (obviously), GPU consumption. I'v seen figures of 5% CPU per NDI channel on a 'modern' i7.
We are running several NDI channels round our building as a test at the moment, and very keen to see what VMIX 17 makes of them. So far our tests are demonstrating that 'bundles' of SDI cables may soon be a thing of the past.
All The Best
Keith
By my understanding watching the fun-time Youtube videos, it is both input and output. They showed off outputting from a office vMix setup to the studios vMix input
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
Been playing around with NDI SDK for a week now and it comes with screen Capture and screen monitoring app. The screen monitoring app allows you to select which window you would like to view.
Hopefully Martin will be adding input, output and tally support via NDI, as I plan to release several windows 10 apps add on for Vmix 17 with NDI support, including Video switching, audio mixer, tally controller and a score board controller for various sports....
