xaxisnl
#1 Posted : 13 years ago
xaxisnl
I am currently using VMIX 2012 v3 (will update to v4 soon) and my question is:
In earlier versions, the playlist was a XML file that could be edited outside of vmix (if you knew the uniquekey numbers).
How can I edit the playlist outside of vmix in the new versions?
Or, maybe easier: is it possible to "dynamically" create a playlist using XML/API?
Thanks in advance!
xaxisnl
#2 Posted : 13 years ago
xaxisnl
Anyone?
