waterprof
#1 Posted : Monday, March 7, 2016 3:58:44 AM(UTC)
waterprof
Since the vMix 16th update I can't change the number of channels, when adding an audio input. Previously I could add an input and change it to 1 Channel, so the sound can be heard in both ears, but I can't do that anymore, it's blank.
#2 Posted : Monday, March 7, 2016 4:06:50 AM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
See the Channel option described here:
http://www.vmix.com/help16/AudioSettings.html
waterprof
#3 Posted : Monday, March 7, 2016 4:51:50 AM(UTC)
waterprof
That help section didn't really help me, perhaps I didn't explain it understandably.
#4 Posted : Monday, March 7, 2016 5:30:36 AM(UTC)
Try changing the channel dropdown to "SeparateMono" which will do what you need.
Channel
Select the audio channel to use for this input.
If you have a Microphone plugged into the left channel or right channel independently. Select SeparateMono here.
Separate mono allows you to adjust the volume of both mono channels independently from the Audio Mixer.
The audio from each microphone will be audible on both the left and right channels simultaneously
waterprof on 3/7/2016(UTC), sinc747 on 3/10/2016(UTC)
Guest (4)
Similar Topics
Zoom Integration Audio Input Issue (General Discussion)
by KevSoleil 5/29/2020 10:17:02 PM(UTC)
